Threads: 5
Everyone:
Since this my first post, I wanted to thank the creators and all the contributors to this site. The info on this site is worth a million.
My temp guage has started to act funny. I think it has to be electrical since it will rise to hot and then drop down to cold in a second or two. I don't think the car is runnig hot. Fluid level looks normal and the fans do not kick in. Also, my speedo will not register until I am rolling at about 5 to 10 mph and then it jumps up to speed and then performs normally.
Has anyone else experienced this issue? Do you think there is a connection between the two?
Thanks.
95 Coupe, Aventurine Green Metallic
Threads: 34
I had the same problem in mine. I just gave it a good "whack" with my fist and it has worked fine ever since! <img src="/forum/images/smilies/968/biggrin.gif" class="smilie" alt="" />
Threads: 5
Thanks to all for your input.
Maybe I'm not running as efficiently as I thought. I live in So Cal so the temperature is normally +/- 70 degrees. If I sit in traffic, the guage sometimes hits 10 o'clock but returns to 9 o'clock once I get rolling. Also, on warmer days, the fans will kick in for about a minute after I shut down.
I think I will have my cap and thermo checked out and get the system flushed. One mechanic that I spoke with told me that the radiator should be completely replaced periodically. Is this true?
Do I need to remove the instrument panel to clean the ground points or can it be done by sticking my head under the dash? Of course, I will try 968Z's "good whacking" solution first.
Thanks again.
Threads: 9
I have a similar issue. My temp gauge bounces around like a pinball for a few minutes upon start, alternating between a moderate temperature and pegged deep into the danger zone. Then it levels off at a nice comfy temp around the 8:00 position for the rest of my drive. I am going to do a coolant flush and fill today and see if it helps. If not, time to yank the instrument cluster, I guess.
My other car is a minivan!
Threads: 9
Ok, so I have cleaned five grounding points, including the two found under the fuse box. Still, my temp gauge is haywire. Also have cleaned the contacts behind the instrument cluster. All this after my mechanic replaced a sensor. Still at square one. Starting to think I may need a new cluster. Thoughts?
Threads: 9
So I also suspected it would not be the cluster. However, the garage that I bring my car to and initially diagnosed the issue as a sensor, proceeded to say it was the cluster when the sensor didn't fix the issue. I declined to have the work done, as I was unconvinced of their diagnosis. Looks like I need to find another mechanic to take a look. I really like this garage too. They are very fair and have done solid work for me. Still, no one is infallable.
Threads: 9
Interesting stuff. I know the garage used temp gauges on the engine when I brought it in buried in the red, and the engine temp was perfectly fine. I will have to check the wiring tomorrow.
