Quote:I just found this thread as I was looking for another. My gauge has never gone to max fill line, except when unit the float was out of the car, and we hooked up the wires independently. The gauge moved up to max line. I have replaced the float unit in the tank 3 times and it never works properly. I also zero out the trip odometer each fill up and when I have driven approx. 180-220 miles I fill it up. By that time the gauge is somewhere near the 1/4 of tank mark. But if it will move up to close to the fill line is anyone's guess.
I never looked into mine, but from all my voodoo internet reading, it is your sender and the grounds most of the time on the trunk side of things. I thought the gauge was resistance based, so the lower the drop the higher the resistance. I thought I read of people calibrating the gauge side, but that was just masking the original problem.
So I think most people either replaced the sender, or took apart, cleaned, re-solders spades, cleaned grounds etc, and got the sender to send the correct resistance for full again.
Remember, any corrosion, etc that can cause greater resistance acts like a low fuel level signal to the car.
Fill the car with gas, pull the sender plug and measure the sender terminals (and remember you are messing with electricity and fuel here)
This is from a 944, so not sure what 968 should read:
Model Year 1985.5-1995 Level Resistance (Ohms)
RESERVE 63.2
1/4 42.2
1/2 21.2
3/4 8.6
FULL (1/1) 2.8
http://www.clarks-garage.com/shop-manual/elect-13.htm
