FS: NEW CROSS COILOVER KIT
SOLD - Thanks 968forums! <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
NEW JIC/Cross flagship coilover setup. Features a light weight, 15 way adjustable monotube damper that ensures high strength and fade free performance. The ride height is adjustable separate from the spring perch giving you maximum suspension travel at any setting. This also allows for proper corner weighting of the vehicle without effecting spring preload settings. Spring rates: Front/16kg/900lb Rear/20kg/1164lb (THE setup for the track). Second set of new springs available if the first are too stiff for you: Front 500lbs, Rear 650lbs. Includes upper pillow-ball mount with built-in camber plates and helper springs. New, still in box, I decided to go in another direction, offers considered. See Cross website for more info: http://www.jic-magic.com/productscross.htm Contact Nick at us944@yahoo.com Thanks, Nick
Last Post by mikeo
07-24-2007, 02:33 PM
