Ethanol in a 968
A new station opened up in my area that sells 93 octane gas with ethanol.
non ethanol 91 is very common and 92 is available at BP/Amoco stations.
What is the general opinion of the group on running ethanol in your 968??
[color="#3333FF"]Todd Jacobs [/color]
[color="#339999"]Iowa, USA[/color]
[color="#FF6600"]1993 968 coupe 6spd[/color]
[color="#000099"]Cobalt Blue [/color] with [color="#000099"]cobalt [/color] and [color="#CCCCCC"]light grey [/color] interior.
[color="#FF6666"]17" 996 wheels, Koni's, LSD.[/color]
If the ethanol mix is no greater than 10% it is commonly accepted that it is OK to use in modern fuel systems. It might be prudent to have a spare fuel filter on hand in case there are deposits that are loosened.
The E85 fuels out there which have up to 85% ethanol, are not compatible.
[quote name='Greimann' date='Feb 24 2006, 10:31 AM']If the ethanol mix is no greater than 10% it is commonly accepted that it is OK to use in modern fuel systems. It might be prudent to have a spare fuel filter on hand in case there are deposits that are loosened.
[right][post="16505"]<{POST_SNAPBACK}>[/post][/right][/quote]
It's unconfirmed but I've heard that the ethanol mixes are not recommended in the older cars because it's hard on the rubber parts in the system...particularly if vehicles sit much. I'm staying away from ethanol until this is proven...
Just me.
Harvey
[quote name='Harvey' date='Feb 24 2006, 01:32 PM']It's unconfirmed but I've heard that the ethanol mixes are not recommended in the older cars because it's hard on the rubber parts in the system...particularly if vehicles sit much. I'm staying away from ethanol until this is proven...
Just me.
Harvey
[right][post="16508"]<{POST_SNAPBACK}>[/post][/right][/quote]
Harvey,
You may be getting mixed up between ethanol and methanol. Years ago, the oil companies began offering a methanol blend of gasoline, and quickly learned that the methanol attacked anything that was rubber in the system. I believe that the majors bought a lot of new engine parts as a fallout of that mess.
Ethanol, though, is a completely different animal, and I am not aware of any compatibility problems of ethanol with any of the materials located in your fuel system. Since ethanol provides an octane boost, you will see higher octane blends, where local laws allow. In Chicago, we can get 93 octane blended gasoline while Southern California disallows that and has a max of either 92 or 92.5 (sorry I don't remember the exact octane limit there).
If there is a problem with ethanol, it has to do with water. Ethanol is hydroscopic, which means that it has an affinity to absorb water. So, if you pick up some water in your fuel system (which can happen if the station operators aren't diligent about pumping water out of their underground tanks), the ethanol will absorb the water from the system. This is OK until the volume of water reaches a point where it supersaturates the ethanol. When ethanol absorbs more water than possible, you get what we call "phase separation", which means that suddenly, the ethanol/water mixture will separate itself from the gasoline in your system. This separation has to very bad outcomes. First, since ethanol provides an octane boost, the base gasoline is blended to a lower octane than required.......and the addition of the ethanol brings the octane up to its limit. So, when ethanol separates from gasoline...........the gasoline will drop to an octane somewhere in the 70's or 80's. Our high compression engines don't really run well (if at all) on 80 octane fuel!
The second negative of phase separation is that you end up with a phase that is an ethanol/water mixture. If this mixture gets into your engine...........you'll find that the engine will not run at all!
When ethanol first became available, as mandated by law, my company (ExxonMobil) paid for a lot of towing and major engine work as cars failed to even get out of our stations without stalling, until we became knowledgeable about the phenomena of phase separation. Since then, we are diligent in monitoring water in our tanks........and the issue has essentially disappeared.
Sorry for the long message. Incidentally, one positive of ethanol is that you no longer need to use any of the aftermarket chemicals to prevent fuel system freezeup at low temperatures due to water in the system. So, you can save your money and not buy any of the STP products.
Quote:while Southern California disallows that and has a max of either 92 or 92.5 (sorry I don't remember the exact octane limit there).
92 I wish. CA has max of 91, with a few 76 stations that carry 100 unleaded, so you can blend up if you want.
We have 87, 89, and 93 at most stations here in PA, with Sunoco offering Ultra 94 and some that still have CAM 2 Purple 104 Octane. I don't recall seeing any blended fuels around here.
Dan-
In search of the right 968 coupe. Midnight Blue or Black.
PORSCHE - "There is no substitue!"
While on the subject of fuels, there is a station in our area that sells 104 (or 101) octane race gas. Would there be any harm in running a tank thru one time, or would it be better to mix it 50/50, 40/60, 30/70, etc....
Performance wise, there is no need to run pure 101, but it won't hurt anything either. One unknown is how far the ignition can adapt to higher octane.
Try this calculator to show the different blends. Maybe go up to 95.
http://www.ranney.com/~mjr/fuel_blend.html
I use 93 w/ethanol I get from a very busy Quicktrip. I beleive all the gas sold in St. Louis City and county has the ethanol mix now?
I was so pleased to find Quicktrip has a top teir rating for their gas because it is very convient from my house (www.toptiergas.com).
Glau
the octane/power rule, as told to me by steve dinan, is 1% raise in octane is 1% raise in power, assuming you can use it (compression, ignition, etc)
i have found that the car seems to run hotter with anything over 95
dyno runs i did showed no improvement over 95, and only marginal improvement over 93 - so, it seems that there are limits
[quote name='Tigershark' date='Feb 25 2006, 08:48 PM']We have 87, 89, and 93 at most stations here in PA, with Sunoco offering Ultra 94 and some that still have CAM 2 Purple 104 Octane.  I don't recall seeing any blended fuels around here.
[right][post="16555"]<{POST_SNAPBACK}>[/post][/right][/quote]
Tiger,
If you live in a rural area of PA, there should not be any fuel with ethanol in it. The ethanol is an oxygenate that lowers NOX output of the engine. NOX is a major constituent of smog. Federal law requires that any area "not in compliance" with the clean air act, must add oxygenates to their fuels. My guess is that Philidelphia should have fuels with ethanol.
Yeah Todd, out here in New Mexico the only gasoline we can buy has alcohol mixed with it from October until March of every year. doesn't seem to do any harm to my 968 or other car either. good luck, bob blackwell.
