Engine tools
So I've started to take everything apart on under the hood to see what all this restore will Intel. I'm having a hard time tracking down all the 968 specific specialty engine tools. Can anyone help me out.
You only need one, the flywheel lock tool
if You really feel the need you can also buy the pin spanner for the balance pulleys
Before I give you some part numbers, is it manual or auto
Pin spanner, only need the cog removal side, cam belt tension is auto on the 968
http://www.arnnworx.com/catalog/index.ph...Ln6Y6hKg-U
If you cant find a slim 27mm spanner,
http://www.arnnworx.com/catalog/index.ph...Ln6vqhKg-U
Porsche Tools
00072191710 Rear Spring Plate tool
00072192000 Balance shaft tool
00072192621 Oil Pressure relief valve tool
00072192061 Flywheel lock tool
about £35 in the UK, but $150 in the USA from the parts places, but $111 from Porsche direct
The manual has all the details of what tools you need for which operation
http://pdlibrary.co.uk/Manuals.php
1986 Honda VF1000 FII
2016 Volvo XC90 D5 R-Design
It's a manual
