Threads: 167
Sounds to me like a wheel bearing or perhaps CV joint...I called Pete to confirm.
I would check those first...if not,
... take it up to 60 mph and lift your foot, if you get an "airplane" sound, that's pinion bearing.
If it is a wheel bearing you will probably to move the wheel back and forth.
Regards,
Threads: 59
You might also want to check your rear tire wear. This cars have a tendancy to cup the inside edge of the rear tires if the alignment is off just the least little bit. That results is a thumping sound, the frequency of which changes with rear wheel speed. When the tires are badly cupped the your car will sound like a 4-wheel drive truck.
The pinon bearing failure in my car resulted in a high pitched whine that sound just like a jet engine was sitting in the rear compartment.
Chris Vais
2008 Audi A5 Brilliant Black
