[quote name='ether_joe' date='Oct 5 2006, 02:14 PM']very informative thank you. my issue is clear, I'm not rev-matching well if at all. hard on the brakes, engine idling, and engaging 2nd gear.
what's the target revs for say, 2nd gear?
also, is it me or are the pedals kind of tough for heel-toe? I can't seem to twist my ankle over that far.
And it's kind of a dangerous thing to be experimenting with. . .
[right][post="26698"]<{POST_SNAPBACK}>[/post][/right][/quote]
For me my target Revs are about 4800 RPM while heel toe braking.
I use the sound of the engine to shift gears and to downshift. Does not work as well on Heavily muffled exhaust.
Example:
When on a straight lets say you are in 5th gear at 6600 RPM traveling at a speed of 138 MPH.
When you slam on the brakes for the next turn you will notice your RPMs start to fall.
When it falls to 4800 RPM I H.T. downshift to 4th (This sends the RPMS back up to 6600 RPM)
As the car continues to slow the RPMs continue to fall and when it gets to 4800 RPM again I HT to 3rd.
Now that my car is in third at 6600 RPM and my foot begins trailing off the brake for the turn my RPM continue to fall but at at slower rate.
The friction created from turn at high rates of speed also slows you down a little which is allowing your RPMs to fall.
Just before the APEX sqeeze the throttle hard and your engine REVs should already be in the sweet spot (REVS should be about 4800 to 5200 RPM when squeezing on the throttle at the Apex to the turn)
As long as you on on a decent line you should be able to get through the corner pretty fast.
