Costco parts organizer...
After work yesterday I textured my walls so that I could paint today. I got up this morning and ran down to Sherwin Williams and picked up $400 in paint (I went with the new Duration paint It is suppose to be the easiest paint to clean if you mark up your walls I love their paints a bit more expensive but it's quality) Anyway had the primer coat on this morning, took a shower and headed over to Costco to return my compressor that failed (Time for a bigger unit!) I try to buy these types of tools at Costco since they have THE best return policy! They ended up being out of stock. We had to pick up some essentials anyway so I did my routine walk down the tool isle. On the main isle they had this new item (see below) The storage box is heavy duty and Heavy in weight 50+ pounds. Well constructed and as the box says over 2000+ different pieces. It looks very similar to the box Griots garage sells. I highly recommend the product it costs $85. There are pre drilled holes so you can mount it under your work bench this is where I am placing mine. Thought I would give you guys the heads up.
When I got home I rolled the top coat, while nicole cut all of the edges. I then cleaned out the garage and sealed the resurfaced concrete. When get up I will install the track lighting, hang cabinets and install the moto floor. I will post some pics when I get everything completed. The project is now getting exciting....
Black 03' Turbo X50
Black 05' Denali
FYI this has to be the same organizer Griot's garage sells for $299.
Looking at the picture in the newest catalog I received in todays mail the comparments have the same exact fastners. It knew they had a similar offering but never thought to compare the two side by side. The difference Griot's private labeled the box. So for $85 this is a steal. I am going to pick two more this weekend for my Mom's husband and my dad Christmas is around the corner!
http://www.griotsgarage.com/search.jsp?searchtext=77077
[Image: 77077_LG.jpg]
Black 03' Turbo X50
Black 05' Denali
I moved this topic to the new "Tool Time" forum. I think every DIY'er needs this product!
Black 03' Turbo X50
Black 05' Denali
This looks great, Eric. I'm going to buy one. Thanks.
Last Post by WJH
06-16-2014, 02:44 AM
