07-12-2009, 11:29 AM
While driving around the block last weekend, I got the Big Red ! . I had just done the speedo gear replacement so I thought a had a connector come loose or not seat properly. Took the dash apart and disconnected and reconnected all 3 plugs.........same thing. Tried to do the blink test and couldn't get anything to blink..............so I did what I always do when I'm scratching my head.....Call Flash. We walked thru the blink process 2-3 times...........no blink. Flash suggested disconnecting the Positive battery lead for an hour and let everything charge down and let the computer reset. Did it.same thing. Just before I resigned myself to a dealer trip, I reached in the throttle body and opened it up by hand to the max, held it for 5 seconds and then looked inside..............the old Check Engine was blinking away. The bolt under the peddle was set too high not allowing the Throttle to open to its max point and initiate the blink test. Damn.
Anyway, the blinking is one long one and then what appears to be 3 kinda short ones then 7 rapid flashes. Looking at the Blink Test codes............there is only 2 with a 7 last position blink. 1) 1117- Oil Temp Sender or 2) 1127-Open Winding of the idle Stabilizer. Flash is going to look into this a little closer today and give me a call, but I thought I would post this everyone could follow along with my frustration and maybe know how to overcome these two codes. The 3 short flashes could be the 1)Sender with the " Second position 2 flash intermittant" signal , or its the 2) "Open Winding" which I don't have a clue what that is or how to fix it. Hope Flash calls befor 3 EST or I'll be way too many beers into this hot Florida day to do anything serious. LOL................
