Threads: 76
Who ever heard of such things? I thought I had all of the parts to do the rear brakes, new rotors, pads, and sensors. No such luck. Luckily my local shop has some on hand that I can pick up in the morning. Most online parts sources do not even list the darned things!
They are mentioned in Vol III of the factory manual - when all else fails, read the instructions.
Edit/Update: The PET only shows them on the front brakes. I found them on the rears. Anyone know if they are required or necessary in back?
Ralph
'77 911S (RIP)
(This post was last modified: 01-20-2007, 12:47 AM by
RPM.)
Threads: 137
I had them on the back, and they're still there <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
Michael Sorbera
aka San Antonio Silver Bullet
2002 VW Beetle TDI
2004 Nissan Titan Crew Cab
1990 Mercury Grand Marquis
Threads: 76
anti-rattle glue - good to know. One pair was no longer usable. I'll check the others.
Ralph
'77 911S (RIP)
Threads: 76
Job is done. New rear rotors, pads, sensors, and shims. Sourced new shims from my mechanic and installed all around. They were not cheap @ nearly $40 for the rears. Each caliper took a 28mm on one piston and a 30mm on the other. This type were self-adhesive and so the glue issue was avoided.
Another great support effort from my shop, European Performance in Raleigh, NC. When I called last night they offered to install all of my parts for just $80 labor. I decided to finish myself (of course I already had one brake apart) and stopped by the shop this morning. They took the time to explain how the shims fit and gave me a few other tips. Great guys. Of course they have gotten a lot of my money on other jobs <img src="/forum/images/smilies/968/blink.gif" class="smilie" alt="" />
Ralph
'77 911S (RIP)
Threads: 69
I too found out about the shims the hard way. The fronts also have two different sizes but they aren't the same as the rears. When I first acquired my car, I was going to do all four sets of pads, but upon inspection, the rears looked almost new, so I left those alone. I did find out that the PO (or shop) didn't install shims on the rears as they were missing and the fronts were a mess. The shims did quiet the rear brakes down significantly. I used OEM pads but will be switching to something less dusty next pad change!
- Darryl
Threads: 76
After lots of reading and discussion I went with PBR deluxe pads. Made in Australia, land of sunshine and sharks! (could not resist that old Monty Python joke) I'll be watching for dust and listening for sqeaks and reporting on the outcome. I hope I chose well...
Ralph
'77 911S (RIP)
