Body mouldings needed
I need help finding some good used parts. I need exterior plastic rocker-panel moulding that fits between the front and rear on the lower LH side of the cat - 3pcs. If you have the RH side as well I would buy to keep colors matcing. I also need the center console arm-rest. It's a one piece plastic unit that includes the arm-rest/ shallow storage compartment. I also need the rear hatch rubber seal: exterior rubber + plastic retainer. Can someone reccomend a good place to buy a shifter bushing? I own a 1993 - black interior and exterior. Thanks.
have you tried sunset?
Stew, try this list of dismantlers. They should have what you are looking for.
http://www.968forums.com/index.php?showtopic=270
The shifter bushing you can get from Pelican.
http://www.pelicanparts.com/catalog/shopca...44M_catalog.htm
Last Post by jim7
04-13-2007, 06:37 PM
Last Post by Brian
10-25-2005, 05:56 PM
