Beautiful 1994 968 Cabriolet
1994 Porsche 968 Cabriolet. Guards red with black leather interior.  3.0 liter, 236 hp DOHC I4 front mounted engine with manual 6 speed rear transaxle. 66,000 miles.
The car has been gone through top to bottom, front to back. The exterior was clayed, buffed and polished to a high gloss. The interior was totally disassembled: the leather seats were repaired; the carpeting shampooed; the dash was taken apart, all electrical contacts were cleaned or, if necessary, resoldered; all gauge lights were replaced; and sound deadening materials was inserted in the door panels. New door and trunk seals were installed. Numerous cracked or broken plastic pieces were replaced - including the front lower ‘batwing' spoiler. The convertible top was dyed, resealed and has no leaks. All engine seals, gaskets and hoses were replaced, and there is no fluid leakage. Everything works as it should, and I would not hesitate to take it on a cross country journey.
I am the third owner of this car. I purchased it from the second owner in California after running a CARFAX), and having a CarChex mechanical inspection performed (copies available on request).
The car is a blast to drive. The engine pulls hard and the transmission shifts smoothly. It corners like it is on rails. I get compliments every time I take it out and no one believes it is over 20 years old. Am selling in order to purchase another 968 to work on next winter.
* Air conditioning
* Automatic cruise control
* Automatic temperature control
* Driver and passenger airbags
* Electric trunk release
* Fog lights
* Force sensitive power rack and pinion steering
* Front and rear stabilizer bars
* Front engine/rear transaxle with central torque tube
* Full analog gauges with warning lights
* Fully lined power assisted convertible top
* Fully galvanized unibody
* Heated windshield washer nozzles
* Leather seats, steering wheel cover and shift boot
* One key central locking/alarm system
* Outside temperature reading
* Pop-up headlights
* Power drivers and passenger seats
* Power heated outside mirrors
* Power vented disk brakes with ABS
* Power windows
* Twenty gallon polymer fuel tank
* Two lockable storage compartments behind seats
* Trunk pass through for transporting longer items
In addition, the following upgrades have been installed:
* 18" BBS-style wheels with Porsche center caps and valve stems
* 225/40R18 front, 265/35R18 rear Sumitomo tires
* Blaupunkt "retro" high power AM/FM/CD/DVD/USB bluetooth stereo
* 5.25" Pioneer coaxial speakers and 1" tweeters in door, 4x6" Kicker coaxial speakers in rear panel
* Driver and Passenger seat cushion heaters (hi and lo temperature settings)
* Porsche logo floor mats
* Woodgrain dash kit
* Crime Guard antitheft/engine demobilizer system with remote door locks
* Express window kits in both driver and passenger doors
* Front engine compartment cover (not included on the ’94 and ’95 models)
* RS Barn stainless exhaust tip
The car has been extremely well maintained. The coolant and brakes systems were flushed in July, 2014, and synthetic oil changes have been performed regularly. The following major items were replaced within the last 25,000 miles:
* AC compressor
* Alternator
* Battery
* Convertible top gearbox and cables
* Cruise control module
* Front control arms, tie rods and dust bushings
* Motor mounts
* Power steering pump, lines and hoses
* Radiator, heater valve and coolant hoses
* Rear crankshaft seal
* Starter
* Timing belt, idlers, tension pulley and balance shaft gear
* Water pump
Included are:
* Removable wind screen
* Convertible interior cover (cover for the passenger compartment when the top is down)
* Triple-layer car cover
* Original window sticker
* Owners manual, Crime Guard manual and Blaupunkt stereo manual
* Two sets of keys with Crime Guard remote plus the valet key
* Porsche electric tire inflator (the spare is deflated to conserve trunk space)
* Porsche tool kit
* 3-ring binder with repair records dating back to 2004
* Workshop manual with supplements and parts catalog on a flash drive
Photos available at:  http://s192.photobucket.com/user/GELewis...0Cabriolet
Asking $21,900
Last Post by 94SilverCab
08-08-2024, 06:12 PM
Last Post by No.15
09-03-2022, 10:51 PM
Last Post by GELewis
03-22-2018, 10:51 AM
