Full Version: Need to re-login every 10 to 15 mins - annoying!
When I became member here I was required to sign in when I first entered the site and then I could stay logged in for a long period of time. Nowadays I need to re-login after like 10 minutes or so. It is extremely annoying since at least every other post doesn't go through and I have to copy - sign in - open the thread again - paste. I have the same computer and same internet provider so I assume that it is some safety feature with the site requires a re-login every now and then. If that is the case I kindly ask to have the time increased. I can accept that a member is automatically logged out if he or she is not active but reading posts or typing replys is not being inactive. The time should be at least one hour or more.
I stay logged in for months at a time. What browser are you using? Are you using AOL?
<!--quoteo(post=76971:date=Aug 6 2009, 05:56 AM:name=banditsc)-->QUOTE (banditsc @ Aug 6 2009, 05:56 AM) <{POST_SNAPBACK}><!--quotec-->I stay logged in for months at a time. What browser are you using?<!--QuoteEnd--><!--QuoteEEnd-->
+1
I use Firefox and also have no issues. The only time I have to re-login is when I transport my notebook from work to home. As it picks up the different IP it requests another log in.
Your issue has nothing to do with the site...sorry you are experiencing trouble.
Regards,
it is set to 1 hour of inactivity
i would suspect either the browser (AOL does not work and vista must have new history enabled) or that cookies are not enabled
Ok, so no prob with the site then.
I'm running mac with safari browser and that may be the cause although it has worked well in past. I have had updates so that may be the culprit here. At least I know now where to look.
i am also mac and safari - no issues there
check to see that cookies are enabled - then clear the cookies set by this board, log out and than in again
I have the same problem on my phone.. It stays logged in on other sites, however not on this one... not sure why.
<!--quoteo(post=76971:date=Aug 6 2009, 07:56 AM:name=banditsc)-->QUOTE (banditsc @ Aug 6 2009, 07:56 AM) <{POST_SNAPBACK}><!--quotec-->I stay logged in for months at a time.<!--QuoteEnd--><!--QuoteEEnd-->
This is a bit off topic, but I always log off every time I leave the site, for no particular reason, just habit. Are there any pros to staying logged on all the time, vs. logging off each time you leave? Thanks.
<!--quoteo(post=76991:date=Aug 6 2009, 10:24 AM:name=flash)-->QUOTE (flash @ Aug 6 2009, 10:24 AM) <{POST_SNAPBACK}><!--quotec-->check to see that cookies are enabled - then clear the cookies set by this board, log out and than in again<!--QuoteEnd--><!--QuoteEEnd-->
+968
