03-15-2010, 11:14 PM
<b>The world needs rational people, I am not one of those people. Here is my story.</b>
I previously owned a 1987 944. Had a lot of fun in that car and drove her all over the west coast from Mexico to Alaska. She died in Alaska and was buried in Oregon.
![[Image: 2343876551_6a1c0d25be.jpg]](http://farm4.static.flickr.com/3177/2343876551_6a1c0d25be.jpg)
<b>December 2007</b> - I purchased a 1992 968 with 85,000 miles. black on black with some basic options. WPOAA2960NS820353
<i>Cost: $12,000</i>
![[Image: 2802915171_14898bf3c2_b.jpg]](http://farm4.static.flickr.com/3012/2802915171_14898bf3c2_b.jpg)
![[Image: 2582771315_02d062db3c_b.jpg]](http://farm4.static.flickr.com/3193/2582771315_02d062db3c_b.jpg)
![[Image: 2583482300_c4d72ee605_b.jpg]](http://farm4.static.flickr.com/3004/2583482300_c4d72ee605_b.jpg)
<b>February 2008</b> Nail in tire. Tire replaced.
<i>Cost: $200</i>
<b>May 2008 </b>- Clutch blows up on me, luckily only 5 blocks from home. This will lead me to RSBarn.com for the first time. Work performed by a local shop in San Francisco, CA.
Cost: +/- $2500
<b>March 2009</b> Time to get ready for my first Paso run.
Cost: +/- $10,000
![[Image: 3520826757_8b89ae95eb_b.jpg]](http://farm4.static.flickr.com/3578/3520826757_8b89ae95eb_b.jpg)
Suspension
Exhaust
Maintenance
Misc
<b>April 2010</b> Coming Soon!
<i>Cost:+/- $15,000</i>
<i>Cost: $200</i>
Cost: +/- $2500
- RS Barn Motorsport Flywheel
- RS Barn Clutch Disc
- Stock Pressure Plate
- Stainless Clutch Hose
- Rear Main Seal
- Fork
- Throwout Bearing
- Misc bearings and bolts
- Slave Cylinder
- Brake system check and bleed
Cost: +/- $10,000
Suspension
- Bilstein Turbo Cup Struts
- Eibach 375Lb/IN Front Springs
- Eibach 250LB Tender Springs
- Bilstein Turbo Cup Rear Shocks
- Eibach 6" 225Lb/IN Rear Springs
- Eibach Helper Springs
- M030 Sway Bars
- Delran Sway Bar Bushings
- Stainless Front Sway Bar Support
- Rear Sway Bar Mount Kit and Drop Links
- Design 1 Strut Tower Brace
- Design 1 Lower Chasis Brace
- Sealed Monoball Castor Blocks
- Racer's Edge Camber Plates
Exhaust
- RS Barn Ceramic Coated Headers
- Ceramic 2 Stage High Flow Catalytic Converter
- RS Barn Cat Back Exhaust with Resonator
- RS Barn Stage 2 Chip
Maintenance
- Timing/Balance/Accessory belts
- Front Engine rollers/seals/gears/tensioners/races...etc
- New Water Pump
- Valve Cover Gasket
- Timing Chain
- Thermostat
- Updated Power Steering Reservoir
- Fuel Filter
- Cap and Rotor
- Magnecor Plug Wires (Blue)
- Some New Coolant Hoses
- Alignment
- Stainless Brake Lines
Misc
- AVIC-f700bt Head Unit with GPS, IPOD and Video
- Professional Detail with a few tiny dings rolled out.
![[Image: gallery_7881_204_17071.jpg]](http://www.968forums.com/uploads/1275846170/gallery_7881_204_17071.jpg)
![[Image: gallery_7881_204_61924.jpg]](http://www.968forums.com/uploads/1275846170/gallery_7881_204_61924.jpg)
![[Image: gallery_7881_204_28970.jpg]](http://www.968forums.com/uploads/1275846170/gallery_7881_204_28970.jpg)
![[Image: gallery_7881_204_31935.jpg]](http://www.968forums.com/uploads/1275846170/gallery_7881_204_31935.jpg)
![[Image: gallery_7881_204_44874.jpg]](http://www.968forums.com/uploads/1275846170/gallery_7881_204_44874.jpg)
![[Image: gallery_7881_204_46302.jpg]](http://www.968forums.com/uploads/1275846170/gallery_7881_204_46302.jpg)
![[Image: gallery_7881_204_81045.jpg]](http://www.968forums.com/uploads/1275846170/gallery_7881_204_81045.jpg)
