01-23-2011, 05:18 PM
The interior light (between the sun visors in a coupe) will only turn on when I have it set to the on when the doors are open setting. When its switched to that and either door is open, the light turns on (as it should). When I switch it to the always (regular) on position, nothing happens (with or without the doors open). I'm not sure why it won't turn on. If I ever need a light I have to open my door.
I am also having locking issues and know the switches in the door jams (connected to the light) can cause the car to think the door is open and unlock. Since the light turns off when I close the doors, this shouldn't be an issue, correct? Could the light not turning on normally be connected to the locks?
Thanks.
Thanks.
