Full Version: M030 sway bar installation DIY / tips?
I'll be installing M030 bars, front and rear, this spring.
Looking for a DIY or any tips others might have before I start...
TIA
Pretty straight forward install. Are you installing Delrin bushings also? If not, I would strongly suggest it. I would also get the support brackets from Pete at RS barn for the front bar.
It's easy but I recommend that you, for the front, mount the sway up before you attach it to the a-arms. That way you can adjust, ie bend, the brackets until you get the sway to turn easily and not bind before you connect the a-arms.
For the rear I'd get the adjustable linkage so that you can eliminate all "pre load" of the sway.
Thanks folks!
