I know some other people who have this problem as well: On my car, the trim piece that surrounds the gauges is sagging in the middle, down almost to touching the top edge of the
[ ! ] warning light - see dotted line below. Has a fix been devised for this?
attachment=9467]
bond a piece of more rigid plastic to the trim on the top side where it won't be seen?
i probably have just what you need here
Are you sure it's the plastic trim piece and not the dash itself? When I swapped in my new dash I found that the dash was causing mine to "sag," more like be forced down.
Adam - not sure about pressure from the actual dash. I can push up on the trim piece and it moves up about 1/4" fairly easily, which leads me to believe there's a gap between it and the dash. I'm thinking maybe a good sized piece of sticky-back velcro in there might stick the trim piece back up to the underside of the dash. Guess I'll have to pop the trim piece off and investigate.
I can do the same with mine, able to push it up easily. I have an extra gauge surround/vent piece if you want to swing by with the car and fit it to see if it makes a difference...I know on my old dash there was no sag.
Now you've got me wondering if I don't need a dash bra too. The car's in the shop, and I don't recall any sag in the dash, but all of a sudden I want to go look at it...
Design 1 Racing "Dash Wunderbra" in the near future?
![[Image: tongue.gif]](http://www.968forums.com/public/style_emoticons/default/tongue.gif)
There is a small screw in the center of the plastic trim piece. If missing, it may allow the piece to sag...Just a thought. Luck
