05-05-2012, 09:28 AM
Need some help here guys.
Took my car into the Porsche shop for the annual spring review, needed inner tie rod ends both sides. So I got that done. Got it aligned, steering wheel seemed off-centre so I complained and got it realigned. Car came back and seemed no better but then I paid more attention and noted an odd issue with steering wheel. Sometimes, the wheel is straight (12:00) when the car goes straight. Then, for no obvious reason, the wheel moves to a position of about 11:30, the car still goes straight. No pull to the side noted. Almost like there is a "washer" or "bushing" missing that lets the rack move around a bit.
Took it back, another alighment, same thing. Was told that the strut mounts were cracked, causing flexing, and that was the issue. Got them replaced and car re-aligned. Alignment specs as per factory standard specs, car has no upper or lower braces and is not M030. Steering wheel still in same 11:30 position, occasionally moving to 12:00 with no obvious reason. It does seem, however, that when I make a sharp right turn followed by driving straight (ie pulling out of a driveway) the wheel has a better chance to be straight for a few miles.
Went to airport on Thursday with a business partner and parked to let him out. Pulled handbrake on as I did not shut the engine off. Drove away with brake on by mistake - only about 10 feet and brake was barely engaged anyway - and then pulled it back off. Steeing wheel was now straight. That is the only thing that I have noticed that actually seemed to be related.
Ideas? Front tires show NO wear to suggest that the alignment itself is incorrect.
This happened once previously a long time ago and supposedly a bushing or something had been left off during a steering rack replacement. That problem was fixed.
![[Image: gallery_81_300_4044.jpg]](http://www.968forums.com/uploads/gallery/album_300/gallery_81_300_4044.jpg)
