05-29-2022, 04:27 PM
Any idea why my 1992 968 would randomly pressurize the fuel system? I have a fuel pressure gauge permanently installed on the fuel rail and have noticed a few times when doing a quick oil/coolant level check (after car has been sitting for a week or so) that the fuel system was pressurized (ie, gauge read 55-60psi of pressure) and thought that seemed odd. I thought it MIGHT be my Focus9 solid-state DME that does "prime the fuel pump" with key on-engine off prior to starting the engine, so I swapped back to the stock DME - observed the same issue. Also thought it might have been something with opening the door and/or hood that was somehow triggering the fuel system to prime/pressurize.
So - I decided to try a test this weekend. After driving the car yesterday, I parked in the garage, opened the hood, and observed the fuel system still had normal pressure (expected, since I'd just parked it). I left the hood opened in the garage, and checked again that evening around 6pm - pressure was down to 0 at that point:
[attachment=14339]
I left the hood opened and closed garage overnight. Came out this morning around 11:30am and found the pressure reading around 12-14psi, which seemed odd (like maybe it HAD been pressurized at some point overnight but had dropped over time?):
[attachment=14340]
I just checked it again (now 2pm) and found the system fully pressurized:
[attachment=14341]
At no point last night or today has a door been opened or keys been anywhere near the car. The hood was left open the entire time. All I've done it looked at the fuel pressure gauge.
Is it possible that the ambient air temperature could "pressurize" the existing fuel system? It's summer here in Texas and the temps are pretty hot. Last night (with zero pressure in gauge) it was still 88-90F at 6pm. Temps dropped to 74F last night. When I first checked the gauge this morning (11:30 - with the odd 12-14psi reading) the air temp was 85F. When I checked it this afternoon and saw it fully pressurized it was 92F. Even if the air temp could cause fuel in system to expand slightly and create some pressure, I'd NOT expect it to get up to 56psi.
Any thoughts? I'm completely baffled.
[attachment=14339]
[attachment=14340]
[attachment=14341]
