08-12-2022, 06:57 PM
Hi Porsche 968 friends,
I have a problem with the headlamps of my car and I wonder could anyone offer any help.
I took my car (Porsche 968, Cabriolet, year 1993) from the garage just one week ago, where it was staying a long time (a couple of years). It started nicely and then I turn the headlights on and only the left one came up and went down but the right one stayed down all the time. The lights came also for the both lamps. So the only problem was, that the right headlamp stayed down all the time.
I checked first the fuse ( number 2, headlamp motor), but it was ok. Naturally, because I assumed, that the fuse number 2 is for both headlamps and when the left was was working ok, the problem is not the fuse.
Then I checked the relay (G17+G18, the combination relay, the big black box relay, Porsche number 944.618.205.00 in the fuse/relay box). I asked my self, if the left headlamp comes up and goes down, is the the relay ok or not.
Can the relay be broken if one one headlamp is working normally. Can anyone help me in this? I hate to spend around 270€ ( around 300$) for the relay, if the relay in the car is ok.
Now I am in the situation, that I have taken the both headlamps up to " a fixing position" by pulling the handle under the lid near the headlamps. In this way the created cap between the fender and the headlamp offers me an opportunity to lubricate the hinges of the headlamp lifting mechanism. But so far I have not succeeded to cure the problem. The right headlamp stays down all the time.
Does anyone know the way to test the headlamp lifting motor, while it is still in the car. The electric wire comes to the headlamp motor and there is a connection and the plug in the wire near the motor. There are 5 connections in the plug.
How I test, if the headlamp motor gets the current and voltage. Which pins in the plug are for what purpose for the motor ?. How can I test it with the normal electric current and voltage tester? Can anyone help me in this?
There are used motors for sale with a decent prices, but again I hate to purchase a used motor without testing first that one I have in the car. And always there is a chance to try to fix the motor (etc. the oxidized collector surfaces and the coals), if it is not working.
I believe, that in this 968 Forum there are many experts of Porsche 968, who may assist me, Thank You in advance
With Compliments and Best Regards
Erkki from Finland, Helsinki
