08-25-2013, 04:10 PM
Inspired by Tama's thread I took the time to do a leak down test on my engine this afternoon. I have a fresh engine with 1,632 miles on it. It's modified with a D1R stage 3 supercharger.
I used a pressure tester used for checking piston airplane engines. The standard for this test is to have a supply pressure of 80 psi and see what the cylinder is able to hold. Normally the test is done on each cylinder with the piston at <acronym title='top dead center'>TDC</acronym> and valves closed. It's also generally done on a warmed up engine.
To do the test I pulled the plugs and rocked the car in gear until I had a piston at <acronym title='top dead center'>TDC</acronym>. I jacked the left side of the car up, replaced the starter with the flywheel lock and did the test. I then had to take out the flywheel lock, let the car down and then push the car until I had the next cylinder in place. Repeat this four times and you're done.
I was very pleased with the results. #1 held 75psi (that's the test shown in the picture) and the other 3 all held 78 psi. I can safely say that my rings are seated and the valves are sealing. When I get a chance I'll also do a compression check, but this leakdown test in my opinion is much more conclusive.
