11-07-2013, 03:32 PM
Finished my first oil change yesterday and I doubt if it could have been easier. Took about an hour of actual work to finish. Let the oil drain while out to dinner and was surprised that not a drop came out of the oil filter when I took it off. It was a Purolator filter which I don't think has a check valve so maybe that helped. I also poked a hole in the filter to help with draining. Thanks to Flash, I already had a strap oil filter removal tool which worked great however the shop that last did the oil put the filter one way, way too tight. In every car I have ever had, I put the filter on hand tight just a little less than full strength. Never had a leak and always make it easy to get off at the next change. I used Mobil 1 15W-50 and it may be in my head but the car seems to run smoother now.
I do have an ongoing issue I was looking for suggestions on. While the car is idling, I get a very small idle hunt that just barely registers on the tach but I can feel the vibration change throughout the car....any ideas what this might be and what to check? The motor mounts were just done not long ago (~year ago) so I don't think that is it.
