01-22-2014, 03:44 PM
Gentleman:
I am replacing front and rear pads on my "92 Coupe. I am having no issues with the current pads other than the fact that I want to install my Porterfield pads.
Fronts went well but when I got to the rears I noticed that there were no "vibration damping plates/discs for the pistons. PET indicates that PN 964 352 096 00 and 964 352 096 01 should be present at 4 each in the rear.
I have been driving on these pads for the past 9 years and have had no problems, vibrations, etc. I know that the pads were changed when I purchased the vehicle.
There is no evidence or marks on the backs of the pads that indicates that they were ever there. Also no evidence that any high temp grease was used between the caliper pistons and the pads.
The Porterfield Pads come with a plate covering the backs of the pads.
Has anybody else noticed this on their rear brakes?
Should I buy the "damping plates for pistons" as Porsche indicates or assume that the plates supplied by Porterfield will be sufficient?
Should I apply a thin coating of high temp grease to the area between were the caliper piston contacts the back of the pad/plate?
Thanks again. All opinions are appreciated.
Carl
Carl
