Full Version: help advice triptronic lights
Just wondering
The triptronic light on dashboard cluster , ....when in manual mode
When its red whats it mean
When its green whats it mean
Does the green light stay on when driving in triptronic
Appreciated for helpAdam
All help
Appreciated
Hi all,
The tiptronic light should go off after start up and D with gear number should be on If I recall correctly.
I do not recall the light being green though. I'm looking into this as I'm having the tip light on in limp mode
After I unplug the plug (pass side) and started the car.
Hi all,
Thought so
i don't remember it turning green, but i don't drive it often. it does though, i think it's only green if you are in manual mode
[quote name='flash' timestamp='1416003239' post='163698']i don't remember it turning green, but i don't drive it often. it does though, i think it's only green if you are in manual mode[/quote]
Yea Thats what I mean
Manual mode
I have no green light telling me I, m in triptronic
actually, while the owner's manual does not specify a "Tiptronic" mode, and instead refers to the two modes as "automatic" and "manual", it always been our understanding that manual mode is in fact Tiptronic mode. the other "normal" mode is automatic.
now that we are talking about it though, i'll have to go over to the tip car and see if the light ever turns green.
Looking forward in the info
And thanks
Adam
No green lights on my car. Always red, in every mode . But in my car that gear(s) light indicator comes on ONLY if I have the main lights knob turned on to at least the parking lights setting, or fog lights or headlights .
Excellent thanks bud
yeah - we know something is up with dan's car though, and the problem is related to the ignition switch. not sure what effect that has on how it operates otherwise yet.
Let me get this clear
I, m, taking about the triptronic light on the bottom of the cluster
Its red most of the time and it says ( triptronic )
But I, m sure it went green when I put in in manual mode triptronic
Oh, that light ..!? Nothing of the sort shows up on my instrument cluster, only the red dot ( hey, maybe our clusters are made in India ) which shows which gear you're in. But that may also be the result of the probable ignition switch or other gremlin that affects which lights come on and when..
"But I'm sure it went green when I put in in manual mode triptronic"
The USA gauge setup has only one light for the tiptronic warning. The bulb is clear and the red comes from the gauge stencil. I notice you're in Ireland which would be a UK based build very different from USA. We get air bags and you get a Club Sport steering wheel on the right. I think you go the better deal getting the club sport wheel. Metric speedo, no air bags. It could very well be you have a slightly different IP than us across the pond. For those of us in the USA, here's a viewing link for EBay UK showing the 968's there. http://www.ebay.co.u...rsche&Model=968 Here's what ours looks like when the key is cycled on. Now, we showed you ours, how about a photo of yours?
[Image: 20141116_101222_zps0936a1c4.jpg]
That "red" tiptronic indicator will always be red. There is a provision for up to three more indicators in that area of the gauge though. So it's possible that where we have a Check Engine and Air bag indicator, you could have a green tiptronic light. If that red tip light stays on you're in trouble.
[attachment=12186]
lol - looks like i'm going to need to take a little trip up to where the white car is so i can see how this works
[quote name='paulzebo' timestamp='1416159453' post='163735']
You can exclude the check engine light as RoW spec cars do not have one.
[quote name='paulzebo' timestamp='1416159453' post='163735']That "red" tiptronic indicator will always be red. There is a provision for up to three more indicators in that area of the gauge though. So it's possible that where we have a Check Engine and Air bag indicator, you could have a green tiptronic light. If that red tip light stays on you're in trouble.
[Image: attachment.php?thumbnail=12186][/quote]
No my triptronic light goes out no probs there
I was only wondering
