10-15-2023, 12:40 PM
Hi all, I'm looking for a bit of advice about a rattling sound my '92 manual cab recently developed. I think its probably not a coincidence that it started a few drives after I used it to teach my daughter to drive stick. Like all of us when we were learning, she did a few bad starts including one particular really lurchy one that I'm afraid might have done some damage!
So now there's a kind of rattle that happens when I hit the accelerator from low RPMs. It happens in gear when pulling out but it also happens when stopped in neutral with the clutch either up or down. You can also hear it going from 1st to 2nd gear but then it is a little less noticeable. It only seems to happen in the low 1-2k RPM range and only while spinning up the RPMs. "Rattle" is the best description I can give: maybe I feel it a little in the accelerator pedal but its hard to be sure. Seems to be more noise than physical, so far. At higher RPMs or after a second or so holding a stable RPM it goes away.
So I pulled out the clutch (btw car only has 30k miles) and found the pressure plate has worn much more around the perimeter than in the center. Its quite a lot: there's a ~1cm wide, maybe 1mm deep, rounded trench that runs around almost at the outer edge. The rest of the plate is flat and it returns to flat at the very outer edge probably just outside the friction disc's contact area.
I used a dial indicator to measure the flywheel's runout and it seemed totally fine (~1 or 2 thou) at the three radii I checked. However I'm pretty sure it must be a bit dished based on how it looks with a straightedge and from the pressure plate outer wear. I didn't take the flywheel out, just cleaned and scuffed it up and reassembled with a a new friction disc, throwout bearing (old one was sticking), needle and pilot bearings. I did manage to get my hands on a new pressure plate but I decided not to use it yet since it is hard to find a green stripe one and I figured I'd save that unicorn until I know for sure what the problem is.
I put it all back together and the problem didn't go away. It maybe sounds a tiny bit different (higher pitched?) but its still basically the same as before. I'm thinking this has got to be a dual-mass flywheel failure, perhaps at an early stage. When the clutch was open I had pushed and pulled on the flywheel and it would move a centimeter or so before weakly returning to not-quite-where it started. But I don't have any specs on what it is supposed to do and this seemed more or less correct from what I found online for other cars.
I'd be fine with replacing the flywheel but damn they are insanely expensive! Like $2400, which is 3 or 4x what a DMF costs for other cars. And I don't even know for sure that it is the flywheel causing the problem. I'm thinking if I have to replace it maybe I'll try the Spec SP86S steel flywheel since that is "only" around $600. But I can't find any info on that model, only posts about the Fidanza lightweight aluminum one that seems too light and apparently causes gearbox noise.
Anyone have any ideas for what else it could be besides the flywheel, or thoughts on how to fix this without spending crazy money on more overpriced parts? Thanks!
