04-07-2005, 12:14 AM
over the last year, many people have asked me about alignment settings - a good alignment is the single best thing you can do to improve your handling - after working with a lot of different setups, i have put together this list of settings - choosing the right setup for you is dependent on the kind of driving you do, what tires you have, and what you are willing to deal with in wander - wander is a very subjective thing - the type of tire, and its condition, are things that will dramatically affect wander - tires with big longitudinal grooves, like the S0-3, will tend to wander more than tires with V patterns like the AVS ES 100 - tire wear is a big player here too - worn tires will do odd things until they wear the new pattern from your new alignment - badly worn tires may never work right
i make no warranties with these recommendations, since i don't know the condition of your car, but they are working nicely in every car we've put them in
a few things you should know:
all below assumes this is a left hand drive car and you drive on the right side of the road
all below are for street cars
alignments should be done with your normal travelling load, you in the driver seat (or an equivalent weight), and about a half tank of gas - this gives you the best shot at a "nominal" condition - don't take no for an answer when talking to the tech
make sure the machine has been recently calibrated (they go out easily)
make sure the machine measures in degrees and not inches
make sure the machine is fairly new (a hunter dsp 600 or something like that is very good)
make sure the tech is qualified - talk to him about what you want your car to drive like and what you will be doing with it - if you get the "deer in the headlights" look, run away
don't assume that the dealership knows what they are doing - you may get lucky, but liability reasons often prevent them from doing custom alignments - also, they usually don't have techs there that really know what they are doing when it comes to custom alignments, and tend to think of alignments as a pain in the butt that most people don't notice anyway
the difference you will see below in castor settings left to right is to adjust for road crown so the car drives straight
RIDE HEIGHT IS CRITICAL - your ride height should be equal left to right and front to rear, loaded as described above - the easiest measurements are taken from the highest point in the fender arch to the ground
make sure your tech has the eccentric adjusting tool, a thin 36mm wrench, and a thin 27mm wrench before you put it on the rack - he won't be able to do the job without them, and many shops don't have them
a word about strut tower braces:
none of these non-stock setups should be done without a strut tower brace - this is essential in order to limit the camber change that the car goes through in corners
you can read about it at: http://www.e30m3performance.com/myths/Stru..._bar_theory.htm
the first set is stock, and for reference
the second set is for a car that is not driven on the track at all, is generally just looking for a bit of improvement, but without any compromise in ride quality - it is also intended for cars with essentially stock suspensions
the third set is for cars who are looking for improved handling, and are willing to accept a small amount of wander (though many get none at all, and this is highly dependent on your tires) - it is also intended for cars with somewhat improved suspensions (konis, M030 bars, etc)
the last set is what i have been using for the last year - i am very happy with it, but realize that my suspension is nowhere near stock, and i am willing to accept a lot more wander than most
i hope these help - have fun, and keep the shiny side up
stock:
FRONT CASTOR L 2.50 to 4.00 deg
FRONT CASTOR R 2.50 to 4.00 deg
FRONT CAMBER L&R -0.16 to 0.16 deg
FRONT TOTAL TOE 0.00 to 0.31 deg
REAR CAMBER L&R -1.11 to -0.41 deg
REAR TOTAL TOE 0.00 to 0.68 deg
modest improvement in cornering and tire wear:
FRONT CASTOR L 3.30 deg
FRONT CASTOR R 3.60 deg
FRONT CAMBER L&R -0.75 deg
FRONT TOTAL TOE 0.10 deg
REAR CAMBER L&R -1.00 deg
REAR TOTAL TOE 0.28 deg
more improvement in cornering and tire wear, but a slight increase in tendency to wander
FRONT CAMBER L&R -1.00 deg
FRONT TOTAL TOE 0.08 deg
REAR CAMBER L&R -1.50 deg
REAR TOTAL TOE 0.20 deg
best cornering and tire wear, but a definite increase in tendency to wander
FRONT CAMBER L&R -1.25 deg
FRONT TOTAL TOE 0.00 deg
REAR CAMBER L&R -2.00 deg
stock:
