Full Version: Power Steering Delete
I saw this and was wondering if this is a common conversion...if so, are you happy without PS?
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...&category=33589
i'm wondering how many turns lock to lock - i'd like to get it down under 3
Delete power steering and get the ratio down to under three turns lock to lock? You'll definitely need the steering system I had in my first Corvette - power by Armstrong.
Not quite the same, but you can simulate the effect by taking off the PS belt.
As for a true mod, assuming it's the same system as for the 944's (I can't imagine why it wouldn't be), you'll be looking at greater lock-to-lock. I got this info from the 944 world:
manual
steering wheel ratio 22.39:1
turns lock to lock 3.84-4.02
power
steering wheel ratio LHD 18.85:1/RHD 18.96:1
turns lock to lock LHD 3.24/RHD 3.26
IMO, it's not a worthwhile modification for a street car, unless your PS system is completely toast.
I've removed the PS pump and plumbing on the race car. I find it gives better feedback on the track plus there is less weight, one less accessory driven by the engine and less stuff that can break. It is a bit heavy handed at low speed but you don't find that a problem on the race track.
I have a manual rack to install but I haven't done it yet so I can't compare.
Eric
I'm thinking of the unit on E-bay...can anybody give me some info on the people selling it?
Is there that much to worry about?
Jason
968Gene,
Thanks for the lead...
I decided to buy this unit and remove my p/s setup.
I'll let everyone know how it feels when done.
Flash, figure I lost approx 10 lbs with the removal of p/s pump and lines?
Jason
