08-20-2005, 02:34 PM
Well, finally got a new DS door handle painted and installed. I found the only way to get all those little plastic arms on was to disassemble the door panel, then move the lock actuator and the metal shield in the door.
All went together fine, but then the car ALARM went off and I cannot shut it off! Had to disconnect the Neg Cable from the battery.
the key operates the lock/unlock cycle properly in the DS door, but the alarm stays ON and the car cannot start because the alarm disables the DME
Reconnected the battery -
Used the key in the DS door to lock/unlock and that works fine, but the alarm stays ON
Owners Manual no help either - l let it blare for 4 min, it shut off. then I used the key in the DS door to arm/disarm, went to start the car and it triggered the alarm again. Had all the doors, hood, trunk, top, etc closed too.
How do you RESET the alarm??
