10-03-2005, 06:45 PM
<img src="/forum/images/smilies/968/blink.gif" class="smilie" alt="" /> Is kinda the way I feel right now!
Just got back from the shop, here's what's up:
1. The head gasket had failed on the bottom edge of no. 4 cylinder - you should see how clean that cylinder is! NO carbon!
2. It was about to fail at the same spot on no.1.
3. Both the head and the block were not warped.
4. The valves were all in great shape!
5. VarioCam blocks are both badly worn - $45 each from paragon
6. VarioCam sprockets on cams were in great shape. <img src="/forum/images/smilies/968/biggrin.gif" class="smilie" alt="" />
7. The little sensor behind the timing belt sprocket for the cam disintegrated - will get a new one.
8. They drained the oil into a clean bucket - had some evidence of coolant. Because of this they want to do new rod bearings. So now the leaky oil pan gasket will finally get fixed!
9. There was a LOT of black gunk in the intake manifold and in the intake ports of the head. They say it's because the previous owner drove it too slow...I'll never be guilty of that!
10. Going to have the injectors cleaned.
Well that about sums it up for now...I'll let everyone know how it progresses and hopefully have some pics later.
They say it will be done Wednesday and I should have the car by Friday!
