03-11-2006, 02:53 AM
Well, I finally got around to smogging the ol 968 today. Went to one smog shop and was told that I must go to a Test Only shop due to the age of the car. So I drove around and found one for only $50.00 out the door.
Results: Machine stayed awhile on the first test which is normally not a good thing as it is checking ,double checking, and triple checking. This was the 15mpg test. 25mph test went by quickly.
15mph
HC MAX-114, AVE-31, MEASURED-114(OUCH-dead even with max, no wonder it stayed here awhile)
CO MAX-.73, AVE-.10,MEASURED-.33
NO MAX-785, AVE-237,MEASURED-646 (WOW)
25mph
HC MAX-88, AVE-20, MEASURED-66
CO MAX-.61, AVE-.09,MEASURED-.38
NO MAX-724, AVE-199,MEASURED-626 (WOW)
Odd thing is that the car runs very strong. Had the Racer-X chip in it. No hiccups, no hesitation. Pulls in all gears. New upper end. No detectable exhaust leaks. Air box mod. New fuel filter. New plugs, cap, rotor. Does have old O2 sensor in it. Idle is fine.
My previous Porsches all smogged much cleaner and I know these cars generally run clean. Though it passed I know it can get better so I will replace the O2 sensor shortly.
Thought I would share.
15mph
25mph
