Full Version: Two Month Update - 968
There are a lot of people that I see looking around for future ownership of a 968, so after two months of ownership, I thought I would give a driving update.
First thing to know is that the 968 won't feel like it has much power. Driving down to pick up the 968 in a 951 is a bit of a dissapointment, so don't do it. After driving it extensively though, you soon realize that the car is decieving. If you decide to find a good straight on ramp, you will easily be in triple digits by the end. Good? Well although I don't get kicked in the butt with the power, it pulls hard when you want it to. So how fast is the 968? Well I have seen everything from 6.5 seconds to 60 to as low as 4.9 to 60. My car is modified, but I am seeing 5.2-5.5 the couple of times I have used the G-Timer. 1/4 is always different on the G-Timer, but the one time I did it, it read 14.2@100 even. I don't know much about drag racing, so I don't know where that stands. What I do know is that I am slower than a lightly modded 951, even with an MR2 Turbo at 230whp to 70, then back even at over 100, even with an STi from a 20 roll, slower than an E46 M3 by a couple of car lengths from 60-110, and a little faster than a Boxter S (like 98-2002). The airbox modification made more of a noise difference to me than a performance difference, but when added with a chip and exhaust, the car is just generally more powerful throughout the entire power band. How much? I don't know, but I would suggest I gained 5-10whp through the entire process. 18's do slow the car down, but after talking to my mechanical engineer friend, its not the weight as my 18's are 1lb lighter in the front, and 2lbs heavier in the rear, but more over the added height. Running 225/40 fronts, and 255/40 rears, I gained about a 1/2" on the front, and 1/2" on the rear. Maybe more, but thats my best guesstimate. On the track, I can't give you an honest opinion becuase my car is modded. So if you want a modded 968, here is what I can offer you. My Bilstein Escort cups with 350F/400R springs, M030 bars at the middle setting, and my ride height at 24" front, and 25.2" rear, fully corner balanced has a hint of understeer with crappy tires. With the new P-Zero's, the car is much more neutral/oversteer. It just lightly fades out at the end, but nothing close to 'oversteer' like Tiff Needel likes. I am going to go to the stiffest setting on the rear bar, and see if I like that a little better. From a stand still, the car WILL light up the rear tires if you are aggressive. Just last night I was going with my friends MR2T and from a 4500 slip, I left about 50ft of deep marks. No wheel hop, and this was with PZero 255's. I haven't found a good point to roll off with because below 4k and I usually bog out without a lot of slipping, or above 4k and I light the tires up. Looks like I am just going to have to ruin the clutch whenever I race...that brings me to clutches. Porsche 944/968 series cars have weird clutches. They are heavier than most, and new clutches bit much harder than other cars I have driven, even ones with 6-puck race discs. Some people like my clutch, most hate it. I have gotten used to it, but I find myself stalling cars that are real easy to drive now. Tires/wheels....man I almost forgot. Get more rubber...the stock 205/225 combo doesn't do anything for the ability of the chassis. 18's may be to big for some, but perfect for me. I am eventually going to buy some 17's for R-Compounds. Camber plays a huge part on tire fitment. I am going to get my car realigned after soon, but with the 18's and 255's, my passenger side rubs and has apparently less camber than the drivers side. Drivers side I had my one 285 P-Zero in there fine, but I couldn't get close on the passenger, thus why I went down to 255's. 255's are really much more than enough rubber for a 968 stock. If you do decide to go bigger, you may want to check your fender lips. My fender lip can only be rolled about 1mm, so I am going to have to end up adding camber or pulling my passenger fender out which I don't really want to do. I have tried heating with a bat, crow bar, etc...and nothing can roll the fender much. There is some insulation or something behind that we can't get out. Everyone praises an LSD, including me. But after driving this car for two months I will give you an honest opinion of a car without an LSD. I have had an E30 M3, E36 325is with more power than an M3, and all of my other sports cars have had LSD's. This was my first car without an LSD in fact. I just knew it was going to be the first 1000 that I spent, but it wasn't and won't be for a while. Why? Well the only time that I have found an LSD to be even close to needed is if you want to slide around in the wet. The tranny will open up easily until you really throw it out. In the drive, I have done one track day, and tons of hard street driving and I have only had one time where I got wheel lift and inner wheel spin. The turn was completely off camber, and not very realistic to good driving roads. In general the car sticks, and if you follow the general rule of slow in and fast out, you won't have the slightest problem, even with 225/50/16's. If you are jerky, a throttle jocky, or just have a passion of power sliding, the of course an LSD might be essential, but for me its not. Last night when I roasted my tires, the diff never opened. Everytime I am sideways, the diff stays locked well enough that I feel safe. So if its a difference of a couple of thousand between the car you want to buy, save the money. I am sure I will love the LSD when I buy it, but I love the car more than enough now with an LSD. Brakes...there are plenty of brakes to go around. I can get ABS to kick in at 80 with ease if I wanted to. Why am I upgrading...well I can get fade with Hawk HP+ and ATE Super Blue fluid. The stock rotors are good, but not enough for high speed driving. Solution, all OEM parts. I am using 996 TT rotors, 996TT calipers, and custom brackets. Easy, simple, and fast. Should be more than enough to get me to do endo's. Tint...get tint. If your car is parked outside, the rear glass is an oven. With my biotherm (thermometer for food) I have reached as high was 130 degrees inside my car with an exterior temperature of low 90's. Clean your grounds, it helps. Many owners are overly cautious on maitenence, but most of the reason is they driving lower mileage, more pristine examples. Your rubber hoses aren't going to bust if you drive your car daily, and your brake lines aren't going to explode if they aren't replaced. The timing belt doesn't have to be done every 15k miles, but should be to insure ultimate safety. I am confident that I can drive my car at less than $100 a month in maitenence if I chose to. This car is honestly the best Porsche for all around driving that I have been in, or owned. It is fast enough to enjoy, sleek enough to not feel 80'sish, reliable enough to compete with a BMW any day of the week, and cool enough to impress your 12yro neighbor (whether it be boy or girl, thats your preference). Its not a 951, and its not a 911. Its its own car that every Porsche owner should enjoy atleast once before condeming front engine Porsches'.
Maybe more later, but for now back to work!
Wes
I had to interrupt my reading of your post, but re the tires rubbing - check your offsets, 18" with 255 should not rub if the offset is correct.
I'm glad to hear you're having fun with your 968.
[quote name='whakiewes' date='Jul 16 2006, 11:44 AM']Driving down to pick up the 968 in a 951 is a bit of a dissapointment, so don't do it.[/quote]That's funny... I just picked up a 951 (stock 86) yesterday in my 968 (stock) and thought that the 951 was disappointing. <img src="/forum/images/smilies/968/laugh.gif" class="smilie" alt="" />
Wes- paragraphs are your friend. <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
Joseph - where do park all of those cars? <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
I am so used to ebay where I try to paragraph it out, and it never works so I stopped. Sorry, I may try to edit it for clarification. Rears are 18X10 ET55 I think. They are from a narrow body 996/993. As to the 951 v. 968, I didn't quite mean it like that. The 968 is completely different...nicer, cleaner, etc...its just that the 951 with 250ft/lbs of torque on tap pretty much gives a rush that the 968 lacks....for now <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" /> .
Wes
[quote name='whakiewes' date='Jul 16 2006, 07:09 PM']As to the 951 v. 968, I didn't quite mean it like that.  The 968 is completely different...nicer, cleaner, etc...its just that the 951 with 250ft/lbs of torque on tap pretty much gives a rush that the 968 lacks....for now <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" /> .
Wes
[right][post="24144"]<{POST_SNAPBACK}>[/post][/right][/quote]
My buddy has a 51, which is what inspired me to get a Porsche. I went for the 68 mostly do to styling and because I was disappointed in his first gear performance. When I drove his 51 again, I feel that what the 68 can do w/o a Turbo is amazing. + My 68 is stock and his 51 has been chipped and he has a few other minor upgrades done to it as well. When he drove my 68 his comment was "I'm wondering why I dont hear the turbo spooling".
As for your comment on the 68 vs a MR2 T I have a deuce also. As much as I love that car their is NO WAY it can stay w/ my 68! and I have a Gen II JDM 3SGTEin it. The problem is that the CT26 falls flat around 80MPH while the vario is still pulling strong.
Now as for the clutch, I would have to agree. I thought something was wrong with my car for the first few shifts. Even when Im driving calm and trying to ease through the gears it dumps and the load tranfer drops the rear end causing a little head jerk. At high RPMs it a minor whiplash. Even with that said its far far superior in driver bliss to any japanese car Ive ever driven.
Hmm...I have only driven/been in modified 951's, so I guess I can't really compare to a stock one. Modified being about 250whp and 280wtq, maybe even 300tq, I don't remember. My car is 'peppier' but no where near the power of the 951. I bet I would pull him in first, but that would be all, if that. The 951's gearing is tall, but with enough power it makes it perfect. I would buy a 968 any day of the week over a 951 as I own one, but my first ride in a 968 was a bit disapointing...felt more like a BMW M3 than a turbo Porsche....which its not, but when you ride 4hrs you just become used to it.
As to the MR2T, its an NA swap with a 2nd gen JDM with the Ceramic turbine. He has an HKS intake, HKS exhaust, 14psi, Burktech Intercooler, and I think thats all. From a first gear roll, we are even until the end of second. Third gear he starts to creep on me. BUT, if we go from a 55 roll, he always pulls me, 5 times in a row. I am in third at about 4500rpms, because if I go to second I won't have much power band. He is at slightly higher RPM's, and that turbo dies at about 6500, but his gearing is so short that he always has power. He pulls about a length on me, but doens't really gain much more. I can never reel him in though until over 100, which his cut hits at 120 so of course I blow by him then. We haven't gotten a good race from a dig in, as I can't ever get a good launch. I haven't found the sweet spot yet, either too high and I roast $300/piece tires, or two low and it bogs out below the variocam kick and I don't have that much power.
Wes
Two months is early to notice, but one of the points where the 968 excels relative to a 951 (especially a modded 951) is in terms of reliability and ease of maintenance.
The 968 motor is rock-solid, but on a 951, you're constantly chasing around vacuum leaks, messing with air/fuel mixtures, and hoping for the head gasket to stay put when you hit the throttle. And too much plumbing -- you can't get to many of the parts in there without taking off half a dozen other crap -- and you need small hands. And the clutch? On a 951 you gotta take off the whole rear half of the drivetrain -- and to do that, you have to take out the entire exhaust system and most of the turbo plumbing. The access panel on the 968 bell housing is absolutely brilliant, IMHO.
Wow, a difficult read! <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
Cliffnotes:
951 feels faster than a 968
Sometimes I burn rubber in my 968
You can't roll the fenders much
IMHO, LSD is only good for wet driving, but I can't wait to have it
I'm adding some 996TT rotors+calipers, and tint
968 = best all around Porsche daily driver
[quote name='chris' date='Jul 18 2006, 11:22 AM']Wow, a difficult read! <img src="/forum/images/smilies/968/smile.gif" class="smilie" alt="" />
Cliffnotes:
[right][post="24210"]<{POST_SNAPBACK}>[/post][/right][/quote]
<img src="/forum/images/smilies/968/laugh.gif" class="smilie" alt="" /> U left out the part about the MR2.
I understand about the MR2 getting out on the launch, Its so easy to take those things from 0 to 80. Now understanding these are different MR2s, my 2 couldn't stay in front of my 68 Through all 5 gears. The 68s power band is very long and with proper shifting, once you enter it, you should be able to stay within it through every gear. So I'm a bit surprised that your friend can make it out of 4th without you being right beside him and pulling ahead. But hey, cars perform different.
interesting stuff Wes. hey here's just a little help-out though
< cr >
< cr >
< cr >
<img src="/forum/images/smilies/968/laugh.gif" class="smilie" alt="" /> <img src="/forum/images/smilies/968/rolleyes.gif" class="smilie" alt="" />
