Full Version: Need a short shifter!
I have decided that I need a shorter throw after driving my buddies 951 with a short shift kit in it. I know there are no readily available shifters on the market, so I have decided to build one myself. I was curious if anyone has a car that is out of commission for about a month or is parking the car for the winter with one that I could use. I will pay you for your time and use, but I would just like to compare the changes between the OEM and the aftermarket, then make my own. I am also going to get better bushings for the entire setup to make it more precise. Best bet is to email me at whakiewes at aol.com if you have something.
Wes
I believe Kokeln makes a short shifter for 968's...
Kokeln did not seem to make the shift much shorter, if at all in the 968 I have it installed in.
