Full Version: For Sale '94 968 Cab
After much reflection, with a new toy on the way, its time to sell.  I'm posting here for a while before anywhere else because I think the members here will appreciate what this car represents, the work done, and the state of its condition more than the GenPop on other boards.
jferraro16@ the Hoo
or
PM here
1994 968 Cabriolet.  Iris Blue Mettalic, Classic Grey (1 of 3). 105.6K miles.
VIN: WP0CA2963RS840496
I’ve had this car for 3 years, with the intention of fully restoring.  Most of the mechanical/maintenance issues that needed attention are complete, as well as performance upgrades; listed below.  I drive it a couple times a week, yet there is still work to do…the majority of it cosmetic/interior.  Interior is in decent shape, just worn.
Great driving, RARE color combo, mechanically sound, looking for somebody to take it the rest of the way.  $14,000.  Will consider all realistic offers, but this price is well valued via Hagerty considering the completed work, parts used and parts included in the sale
Mechanical:
-Engine opened, complete inspection, gasket and bolts replaced
-Engine mounts replaced
-Cam chain, tension pads and oil tube replaced
-Plugs, wires, distributor and rotor replaced
-Knock Sensors replaced
-Oil sensor replaced
-Starter wire replaced
-Crank sensor replaced
-Top of engine clear powder coat
-Fuel Feed and Return lines replaced
-Front wheel bearings replaced
-Brake discs and pads replaced, Parking brake springs replaced
-Clutch hose, master and slave cylinders replaced
-Control arm bushings replaced, alignment
-Sway bar bushings replaced
-Voltage regulator replaced
Performance:
-RS Barn Stage 1 chip
-Airbox cold air modification, K&N Filter
-Club Sport steering wheel/airbag delete
-993 17” Cup II Wheels, Michelin Pilot Super Sport tires (1/2015, 800 miles)
Cosmetic:
-Eruo-style turn signals/front ”bumperette” delete (old ones retained as parts)
-Front & rear bumper covers, both side mirror housings repainted
-Front lower grid and batwing (front apron) replaced
-Rear brake light housings replaced (old ones retained as parts)
-Roof boot replaced
-Instrument panel repainted, bulbs AND reflectors replaced
-Black leather shift boot
Parts included, uninstalled:
-Original 15” 968 wheels/center caps
-Original computer chip
-New spare DME relay
-Used interior windshield trim pieces in black
-New ignition switch
-New interior door handles in black
-New exterior door seals, door handle seals
-New forward side-skirt seals
-Overhead light with LED bulb
-Drivers side black plastic dashboard trim
-New hood liner
-AC and power steering struts
Known issues/full disclousure/to do list, but functional:
-Power steering very minor/slow leak & cooling hose/coil to replace
-Never got around to struts/shocks
-Hood and trunk lid repaint
-Radio & clock inop & disconnected awaiting interior rework
-Belly pan/batwing (front apron) has some zip-tie assistance due to bent fittings & wheel well plastic wear
[attachment=13239][attachment=13240]
