09-04-2007, 03:31 PM
So my hatch motor seized up last week when I tried to open the hatch. It actually kept trying to open without me knowing it, and proceeded to drain my battery. Anyway, I pulled the motor and replaced with a tested "good" replacement from a Porsche recycler. I install the replacement, turn the key and ....
Nothing. Well, not nothing.. it did blow the fuse associated to the circuit. I am assuming I got a bad motor. The seller responded and has no problem swapping the item or issuing a refund. But before I make it his problem (He is being a really good merchant), I want to make sure I am not missing anything. I did try to run the motor unconnected to the cable, to make sure it wasnt a seized cable or anything... still nothing. Is there any sort of relay in this path that could be the culprit? Any other ideas?
Thanks in advance for any direction. I have a new issue seemingly daily, but it is only because I am trying to invest time and care into a ride where the PO let some little stuff go over time.
