12-21-2007, 10:14 AM
Hi guys,
I changed my water pump on my 968CS about 10 months ago due to the old one showing signs of leaking. All has been going well until a few weeks ago when all of a sudden the red light came on. No sooner had I pulled over when I noticed the temp needle dropping from the 10 o'clock position down to the first white line (7 o'clock) in literally 4-5 seconds. I drove home and a had few more trips afterwards and all was fine - no overheating.
I then drove it again a few days ago and the same symptoms appeared... overheated whilst driving, then temp dropped to normal. I noticed that my overflow is ever so slightly leaking some coolant through the radiator cap, hence I do believe it's under immense pressure and definitely overheating rather than a faulty guage. From the symptoms I suspected I had a problematic thermostat.
After reading the forums here, I decided to change it myself and succesfully changed the thermo to a new one. (After changing it I noticed by the manufacturing date that the thermo had indeed been changed when the new pump was installed earlier this year). Anyhow, I then started the car and simply idled it. Sure enough after 15 min. it overheated again.
Now, I did lose some coolant when I pulled both the bottom hose and the thermo out. So, I was thinking that after a while I would see the overflow level drop down to make up the loss, but it never did. Should I have be bleeding the system for air locks possibly (where do I do that?).
Unfortunately, nothing changed in the overflow level and it didn't get hot at all in that area so water was not circulating even when hot. My water pump exterior got to about 70 degrees celcius (measured with laser temp gun)... also the thermo fans did not come on at all (aircon was off) . However, I do know that they were coming on when I was driving although that could be due to the air-con being turned on. (what's the difference with the thermo fans when you have aircon on vs off?).
So, does anyone have any idea where I should look to next? Is it the pump that maybe has a fault or a radiator blockage?
Any suggestions are much appreciated as I'd like to get the car on the road for the festive period.
Regards,
Steve
Regards,
Steve
