01-23-2008, 09:40 PM
When researching the highly-recommended Gates belts (thanks for all who chimed in on that topic), I noticed Gates also makes rollers for the 968, which makes me wonder whether the entire drive belt assembly wasn't originally built by Gates. Are they a good source for rollers, or is there a better source, like the dealer or Paragon?
Also, since the balance shaft belt is under so little stress, is replacement of the balance shaft rollers really necessary? I did just the balance shaft belt a couple of years ago when the old one sheared a bunch of teeth (belt was the wrong width), and the rollers seemed perfect, so I kept them in there.
Finally, I assume replacement of the timing belt tensioner is recommended, which makes sense. Any recommendation for a good source for the tensioner? Thanks!
