02-06-2008, 11:08 AM
Changed my brake master cylinder last weekend, and the replacement part has an extra port. So I ran down to Pep Boys and got a bleeder screw which threaded perfectly into the hole and tightened it securely to close off the port.
No sooner do I pressure the system to 12 PSI with my power bleeder than I notice a puddle of brake fluid on the ground below the master. The rubber cap had popped off and fluid was leaking out, even thought the bleeder was quite tightly fastened in place.
Why wouldn't a bleeder screw close off the extra port? I don't think I could tighten it any more as the threads might strip out. It did occur to me that the port itself is made to accept a flared brake line end, so could this be incompatible with the bleeder's tapered point? I've never looked down into a bleeder hole on a caliper to see what it looks like, but perhaps it's different?
