Full Version: Customized 968 in Monterey CA
This weekend at Porsche's 70th anniversary bash
[attachment=13528][attachment=13529]
Interesting wing.
I have those same Aerocatch hood latches.
So there are shops to which you send your hood and they build vents and latches in it , or do you purchase the entire replacement aftermarket hood like that and just have it painted ?
Turbo RS air vent , to go with the huge top opening in the modified and good looking front PU
Not sure I like that huge rear wing though
Vafa owns this - he is active on the Porsche 968 Enthusiasts facebook page.
Met and talked with the owner on Saturday.  It appears to be a faithful re-creation of a Turbo-RS.  Saw the engine bay and it's immaculately done.   The engine is from a 944 as it should be if it were a true RS.   He said it's an S2 engine that's been turbocharged.
I would like it better if he had selected the Speed Yellow or Red for a Turbo-RS.  Regardless....very nice owner who has clearly put a lot into the car.  While I was there, they fired it up and left......sounded fantastic.
That wing isn’t that big and the angle seems steep. Looks cool though. Wonder if they’ve done any testing on it?
So he had the OE ( factory ) 951 turbo kit , or an aftermarket turbo ? One of the bay area 968 guys had a Powerhaus turbo which was producing about 480 HP , IIRC, but there was also another version with less HP a couple of other 968 members were considering at the time , because the " big one " required so much maintetence , the car spent more time in the garage than on the road.
Thank you all for your interest in my 968.  Here are some specs:
1993 Porsche 968 Turbo RS Tribute
Specs
- Lindsey 3.0L 4-cylinder 8v engine
- 274 Web-Cam
- Cometic Head-Gasket
- Garrett Super 65 turbo
- Complete Lindsey fuel-rail
- Bosch 044 high-flow fuel pump
- Lindsey Stage 2 Intercooler
- Lindsey heat treated manifold
- 3" exhaust
- Vitesse MAF
- Motion Control Suspension (MCS)
- Billet aluminum Charlie A-arms
- 6-speed Getrag transmission with Guard Transmission (GT) Limited-Slip- Differential
- Fidanza billet aluminum light-weight fly-wheel and Stage 5 solid 6 puck racing clutch
- 993 Turbo brake calipers in black with large rotors
- Additional oil cooler in front
- 4-point roll cage
- BBS E88 racing rims 9"x18 front and 11"x18 rear
- RH 3.6 Turbo Speedline-look rims 8,5” x 18” front and 10.5” x 18” rear
- Bridgestone RE-71R tires 245/40R18 front and 275/35R18 rear.
Vafa
Classic Turbo RS wing.
[attachment=13532]
Nice car Vafa,
They must be just about the biggest wheels you can get in the arches,
Very nice tribute indeed
