added weight impact
Is there a formula that determines what impact weight has on the acceleration of the car ? Could it be possibly directly proportional to the car's weight ratio, as in...adding 300 lbs to a 3000 lbs car will slow your acceleration by 10% in all gears troughout the entire rpm range, your 0-60 and your Q-mile time will be 10% longer, etc.. ?
i have it - i'll send it to you
