i have 300# springs up front on my car - there is no way i could do that with stock torsions and have this car feel right to me - been there done that
keep in mind that i differ in philosophy of setup from most - i presume that the car will be driven to its limits regularly - i do not presume it will only be driven around town - for this reason i am uncompromising on things like balance
if i was really motivated, i could do the math to show it, and calculate the natural frequencies of the suspension based on wheel rate, but 300 is too stiff without adding rear springs - 250 is even a bit too stiff, though a lot of guys do it - i think maybe they just don't know what a balanced spring setup is supposed to feel like - i know the front end seems to be able to take a lot of spring before it feels too stiff on the street, but it takes very little to throw the balance off, and there are a couple of roads here where i could quickly demonstrate it - again, on the street, you won't notice it, and things will feel "fine"
to put this in terms that might make more sense, i will preface by saying that i come from a very tiny very lightweight car with very little power - this is referred to by racers as a "momentum car" - on cars like that, suspension is everything, and there is no room for flopping around or losing speed due to poor weight transfer or understeer or oversteer - this meant that i had a chance to really play with spring balance, and learn the finer points of what makes a car fly through corners - i had to learn the hard way sometimes, by having a car get out of control, but it did eventually result in being able to tell what a car is doing by feel
back to our car - the front tires on the 968 are already too small relative to the rear, and certainly for the weight of the car - porsche did this as a cosmetic congruence with the 911, and for reasons of cost (probably to keep the 968 from beating the crap out of the 911 too) - it was not by engineering design - this leads to understeer that already needs to be overcome - adding more is not advised
heavier front springs will only exacerbate this if you don't balance them in the rear
i have played with many different spring rates, both front and rear - i am pretty sure that 300 will make you as unhappy as it did me if you take the car to the edge - i started my journey with 300# eibach springs on yellow konis with stock torsions - the rear was soft and the front was skatey, no matter where i set the strut - it was fine on the street, but as soon as i took it to the edge, the natural frequencies showed up and on an undulating road, the front end was dancing to a different tune than the rear
the rear konis will NOT add spring rate (beyond the 25# of gas charge) - spring rate is measured by a constant load, not by deflection rate - deflection is just rebound rate - cranking up the konis will increase the rebound rate, and make it "feel" stiffer, but it won't add any spring rate - around town things will be just fine, and the car will feel more fun to drive - however, you will find out the first time you set the car in a hard long corner just what is really going on - where the rear resisted bumps at lower speeds, and felt stiff, it will now just drop down and sag relative to the front
remember that the car is set up with 160# (150# wheel rate) up front and 175# wheel rate in the rear - this is the appropriate front/rear ratio for the car weighted as it is and the tires staggered as they are, with the swaybars stock - you can tell this easily by how the car handles bumps and dips in a turn - the front and rear move together at the same rate - when the front dips, the rear dips the same amount and recovers at the same rate - this is the key to the car's natural superior handling
if you add larger swaybars, you can move the ratio closer to 50/50 because less weight is being transferred side to side, and the nature of the macpherson/banana combination changes in relative dynamics
if you add front tire width you can start to go a bit heavier up front relative to the stock front/rear ratio because the extra front rate won't add as much understeer, but the natural frequency is still an issue (keep in mind that this is "wheel rate" and not just spring rate, as the front suspension is 94% of the spring, but the rear is only 56% when using coils
i would choose 225# up front if only doing shocks in the rear - i know that seems soft, and hardly worth the effort, but the key to handling in this car is in the rear suspension, not the front
i know pete and i will disagree on this, but i've installed both sets and gone around the track - the balanced setup was faster, even though it leaned more and felt less aggressive, and was less fun to drive around town - again the difference in our approach is largely philosophical - i tune all cars with the nutty or aggressive driver in mind, and he tunes street cars with the average driver in mind, and feels that this is still an improvement over stock - i can't say i disagree with that
just for reference, i have since played with a lot more rates, and still come to the same conclusions - my front /rear wheel rate is now 282/280 using 300# eibachs up front, and 500# eibachs in the rear (no torsions) - the car is perfectly balanced in spring and all 4 corners do exactly the same thing at the same time and the same rate - this has not been an easy course
suspension choice is often a lot like a cat-back choice - while it won't add power, and may even cost you some, the experience is often improved, and that is what matters most to a lot of people
good luck
