Hi Rolls, you live in a hot climate so the plastic will suffer if previous owners have left the car out in the sun .... especially in Summer. I brought mine back from the middle east. For the most part it is fine, but there is sun damage (fading) on the top of the dash and the side panels on the windshield are a bit warped. You will encounter brittle old plastic .... it happens; heat of engine and heat of the sun. So don't despair, these are fine cars, fun to drive, and you will encounter plenty of support on this forum.
As a matter of interest .... your rear hatch. I'm presently having a discussion with snova on this. A quick test for your rear latch ...
1. Does it open with the footwell switch? (If yes, then I assume your comment about rear latch fail is that it doesn't open with the boot/trunk key)
2. So if the footwell works, discern if pressing the footwell switch for different lengths of time results in motor movement of different lengths of time.... you can either hear this, or note that the rotor arm stops in different places.
The motor should run for the same length of time and park in the same place (approximately) for each press of the button, whether that press be long or short. It is similar to windscreen wipers .... when you turn them off mid-wipe, they still sweep until they park. A proviso for the button press is that if you hold the button for a long time (say two or three seconds) the motor should overshoot the parking spot and loop around again.
If the duration of the motor movement appears to mimic the duration of button press, then there's a good chance that the problem is the switching mechanism inside the motor housing. I don't know how difficult the motor is to access in a coupe, but on my cab it is not much effort.
Have a look at "key won't open trunk" or "rear hatch wiring" which is just a a couple of post prior to your one.
Good luck
