06-16-2015, 10:19 PM
The time has come to let go of my 1994 Guards Red / Cashmere 968 with 143,500 miles for $7000 or best offer. She is setup as a streetable drivers ed car with a full interior in good condition. I am hoping to find someone who will enjoy and care for her as much as I did.
She was my daily driver for several years, and then garaged at my parents house since late 2011 and driven every month or two. I recently spent a lot of time and money prepping her for sale, only to discover that she needs a new head gasket during the VA emissions inspection, hence the low price. The estimate for the repair is about $3600 and is attached below. Despite the problem she runs well, and is registered and inspected in VA. If you are looking at comparable cars, keep in mind that all 968s need a head gasket around this age and mileage.
Other than the head gasket, she is in excellent mechanical shape and has many new or recently-replaced parts, including a new windshield, 1st and 2nd gear synchros, steering rack, etc. See below for a full list. I have detailed records going back to 2005 from the previous owner, including the original Porsche service book. She was serviced at Precision Motorsports Racing in NJ, then RS Barn and Performance Automotive in PA.
Please send an IM with your email address for additional pics or to schedule a drive. The car is at IMA Motorsports in Chantilly.
Andy
Steering and Suspension
Andy
- 8/2008: Hypercoil main front springs (450lb) and Eibach tender springs (150lb) give a progressive spring rate feel.
- 8/2008: Eibach main rear springs (250lb) and torsion bars (150lb effective rate) give a progressive spring rate feel. Helper springs keep the suspension loaded under full droop. Rear springs upgraded to 325lb in 2010 to dial out understeer.
- 8/2008: Bilstein Turbo Cup shocks custom-valved to RS Barn specifications
- 8/2008: OEM M030 (sport package) front and rear sway bars. Rear bar has 3 levels of adjustment, but is best at full-stiff.
- 8/2008: Delrin sway bar bushings and solid sway bar mounts improve sway bar performance. Delrin bushings replaced in 2011.
- 8/2008: Design 1 strut tower bar and lower chassis brace tighten up handling
- 8/2008: Monoball castor blocks make a noticeable improvement in handling precision. 8/2010: replaced under warrantee.
- 8/2008: Front camber plates make alignment fully adjustable
- 8/2008: 17x7 front and 17x9 rear 993 Cup wheels
- 6/2009: Racer’s Edge front control arms with 19mm pin and solid bushings (OEM 17mm pins have been known to fail)
- 6/2009: RS Barn Solid billet front hubs replace the OEM hubs (which have been known to crack)
- 6/2009: Rack Tack steering rack bushing improves steering feel
- 3/2010: Original OEM rear suspension bushings replaced with solid bushings to tighten up handling
- 4/2010: Replace steering rack with rebuilt OEM
- 5/2010: Replace steering shaft with OEM
- 3/2011: 14mm front spacers improve steering feel and reduce understeer
- 8/2008: “Airbox mod” – adds 4 holes and trim rings to the airbox to allow more air to flow in
- 8/2008: RS Barn chip tuning improves the drivability by filling in the dead spots in the throttle
- 8/2008: RS Barn cat-back exhaust gives a minor performance improvement and adds a nice exhaust note with no drone. 4/2011: Muffler replaced under warrantee.
- 9/2008: Radiator, expansion tank, temperature switch, and all cooling hoses replaced with OEM parts
- 9/2008: Low-temp thermostat switch
- 4/2009: Design 1 exhaust heat shield keeps heat from the header out of the engine bay
- 4/2009: Design 1 firewall brace reinforces firewall to eliminate the possibility of cracking over time (known issue with 968).
- 4/2010: Replace oil pickup tube with OEM and install Lindsey oil pan baffle to eliminate possibility of oil starvation under cornering
- 4/2010: Replace rod bearings with OEM parts (standard maintenance)
- 4/2010: Replace motor mounts with OEM parts
- 4/2010: Add Lindsey 3-piece cross-member to reduce cost of future rod bearing maintenance
- 2/2011: Replace distributor cap, rotor, wires, and plugs
- 2/2011: Service cam chain and replace tensioner pad
- 2/2011: Replace power steering hose, flush system, and replace fluid
- 2/2011: Odyssey lightweight battery and mounting kit
- 2/2011: Add remote kill switch (track event safety feature)
- 9/2014: Induction clean and mass airflow sensor clean
- 9/2014: New spark plugs
- 8/2008: Stainless steel clutch line prevents clutch line failure (known issue with 968)
- 1/2009: Transmission rebuilt with new 1st and 2nd gear synchros (2nd gear synchro is a known weak-point)
- 1/2009: OS/Giken limited-slip differential provides better acceleration out of corners and improves stability under braking
- 4/2009: Design 1 short-shift kit improves ease and precision of shifting
- 6/2009: RS Barn PCA Legal lightweight (18lb) flywheel reduces rotating mass for better performance
- 6/2009: RS Barn Hybrid ceramic/Kevlar clutch provides reliability for track day use
- 6/2009: OEM Porsche pressure plate and miscellaneous parts for clutch job
- 8/2008: Turbo Cup ABS regulator (brake bias valve) moves braking more to the rear for better balance and less sensation of weight transfer
- 8/2008: Stainless steel brake lines improve braking feel
- 10/2008: Front and rear brake calipers rebuilt with new pistons and seals for reliability
- 10/2008: Front brake ducts added in place of fog lights
- 4/2010: New brake master cylinder (proactive replacement)
- 2/2011: OEM Porsche brake rotors
- 8/2008: 50% tint on door windows and rear hatch glass is almost invisible but helps protect the interior and keep it cool
- 9/2008: Replace upper and lower front grills
- 10/2008: Euro turn signal lenses replace the US lenses and bumperettes
- 11/2008: Porsche 968 car cover
- 3/2010: Add rear tow hook
- 4/2013: New OEM windshield
- 8/2008: Recaro Speed seats bolted directly to sliders
- 8/2008: Momo steering wheel (retains horn button)
- 9/2008: Textured aluminum gas, brake, and clutch pedals
- 4/2009: Window Express auto-up/down window electronics for driver and passenger doors
- 3/2010: Fire extinguisher mounted in front of passenger seat (required for PCA track day events)
(This post was last modified: 06-17-2015, 01:58 PM by pure&simple.)
