1993 6-spd Coupe - $10,500
6-spd coupe, black/black. Two-owner car; maintained very well, only 3,000 miles past four years (documented by DMV records), 139k miles.
-All maintenance up to date, including oil and filter; plugs and fuel filter.
-Upgraded suspension with Koni shocks and struts ($1200 Paragon kit w/rear coils).
-Within the past 3,000 miles, the following work has been done: brake rotors and pads, clutch and all components, head gasket, starter, timing belt/water pump, alternator, head gasket, compressor (AC blows ice cold), oil pick-up tube, rod bearings, chain and pads replaced, SS brake lines. Car has been professionally lowered. Engine and transmission have zero issues. Upgraded Sparco Sprint seats. All electrics work as they should. You will be hard pressed to find a 968 in better mechanical condition.
I have all receipts for all work stated above. All engine work done by Max at Provost Motorsports in Bordentown, NJ. I did the suspension and brake work myself.
Body is in very good shape for a car of this age, but it is not a concours car. Paint has good sheen as you can see in photos. Some dash cracking. Could be a very niced DE car with not much more needed to be done.
Price is $10,500, very fair for this condition car. My loss is your gain!
Located in central NJ. Email me if interested: rlerman9 at geemail.com.
Photos
https://plus.google.com/photos/116763247...7zItb29qwE
Last Post by Bandini
05-16-2024, 10:50 AM
04-13-2024, 07:54 AM
Last Post by pdxmike
05-09-2021, 04:49 PM
Last Post by Pmari
10-18-2015, 02:27 PM
