Anybody running this setup? Problems?
(Rear) Porsche part number (2) 996 362 140 07 18x10 65mm offset 5x130 bolt pattern
(Fronts) Porsche part number (2) 996 362 136 07 18x8 50mm offset 5x130 bolt pattern
Cheers,
Those widths and offsets will fit without problems.
i'm not so sure about the rears - depending on a few things, those could hit on the inside
Bob is correct. I'm running those widths/offsets with Sport Classic IIs. If you run 285s or any negative camber, you will want to push them out a bit. FYI, I run 275's, 17mm spacers, -1.5 negative camber and have the exact look I was going for. Also, a bonus with the front width is you can clear the hub without spacers (unlike the 7.5" fronts).
Regards.
Rustech
I am my running 18's on my stock car with no problems.
front tires are 225/40/18
rear tires are 285/30/18
I think if you go above a 30 on the rear it will rub.
it is not the profile, but the offset that is the key here - you can run a 35 series, or even a 40 (i've seen them both), if you have the offset correct, and don't have too much negative camber
sorry didnt list my offsets, front 50 rears 65
ah - well then it's just dependent on the camber angle and brand of tire then, because we have seen 10s hit the inside on a 65 offset, even in lower profiles
Looking to use these or a track car so some camber will be part of the setup. That being said any track cars using this setup?
Cheers,
personally, i would put longer studs on the axles and add spacers, likely 7mm, maybe 10
Sorry, and I didn't mention I was lowered [img]style_emoticons/<#EMO_DIR#>/rolleyes.gif[/img] I thought everyone lowered their car [img]style_emoticons/<#EMO_DIR#>/tongue.gif[/img]
Rustech
